E12 T Sport Springs
KJMTSPORT
Hi All,
I own a pre-facelift CTS (2002) and looking to lower it.
From previous topics, the facelift CTS are 15mm lower than the pre-facelift CTS.
Would it be possible to fit a set of facelift springs to my pre-facelift, to lower it by 15mm???
Thanks in advance
Kevin
:thumbsup:
Hi All,
Thanks in advance
Kevin
:thumbsup:
This would be pointless, the standard TTE springs are perfect, the car sits well and isnt pimp my ride low, i will stick a pic up for you to see :thumbsup:
Lowering a car by 15mm does seem a bit pointless.
It's such a small amount you wouldn't see any difference.
:thumbsup:
Hopefully the below shows the car sits how it should of done when leaving the factory :)
Looks good :yes: , mine is the same colour but a 3 door.
TTE springs, found them on the TTE website
TTE
Few Q's Cabcurtains:
Are these what are fitted?
How much were they?
Direct from TTE or Toyota Dealer?
The TTE springs were £140 approx, the labour is a bit tricky as i had a a leaky shocker so i had the springs the same time. I would guess 2 - 3 hrs of labour for 1 person to do all 4 corners. Supplied by Mr T.
Fensport sell the same springs marked as Eibachs, i think they're slightly cheaper. :thumbsup:
AE102 has the same car as you on Eibachs.
http://www.tte.de/popup/TTE/cm_corolla_E12...ringsprings.htm - Your link is for the facelift car, however the parts could be the same.
