Corolla 1999 Alarm To Senstitive Help Disconecting
pearcie
hi i have a toyota corolla 1999 and the alarm is to sensitive goes of when there are loud noises plastic bottles in the car high winds anyway just wondered is there anyway of disconecting it without stopping the car from starting or central locking working also i dont even know where it is located looked for it but cant see it i dont need a alarm so i would just be happy to disconect it plus the neighbours would be a bit happier......thanx in advance fot any help
Last time i installed a car alarm, i put the control box behind the glovebox, try there and see if anything looking like for the car alarm.
Or, if it has a separate horn for the alarm then just disconnect that instead, but if uses the car horn then leave it.
Hope that helps
Hope that helps
ok thanx for reply
