Engine Difference's Between 140 And 190 Gen 7
fazzer
does anyone know what differences there are between the celica 140 and the celica 190 bottom end.is the block the same?crank and pistons the same or different,any pics or literature on this subject
thanks in advance
the engines have slight diffrences im not sure how much diffrent
i know the 190 has 2 camshaft and operates two lobes per cylinder one high rpm one low rpm aswell aswell as two intake valves and two exhaust valves.
im only after the differences on the block as i know the head set up is different
