Engine Oil Pressure Light Problem
hows she now
Hi, Can anyone help me with a problem with an engine oil pressure light on my D4d 'o5 engine.
I pressure washed the front of the engine block a while back and for a while after the oil pressure light was flickering on and off. I forgot about it thinking it would dry out.
Now the oil pressure light has gone off completely, even with just the ignition on!
I have tried grounding the wire that connects to the pressure switch with a phase tester to try and see if its the pressure switch thats defective but the dash light still won't come on.
Q. If it is the dash light, how big a job is it to replace it. (From the schematic it doesn't look like a conventional bulb). It shows it as a "Combination meter"?.
Your help would be greatly appreciated.
If your pressure switch has a single wire, the only thing it can do when switching is to earth the circuit or break the circuit. (normally they earth to switch on the light, break to switch off). Ground the wire to the cylinder block (ignition on) and see if the light comes on (without the phase tester). Chances are that it will and you need a new switch.
hi
are the others ON before starting?
any fuses serve this circuit? may be the problem is there?
cheers
be careful mate a friend of mine has a o4 toyota avensis and the oil pressure pump went no warning even seems the 03-05
had this problem faulty with avensis
quote name='igormus' date='Oct 1 2008, 07:20 AM' post='806284']
