Side Light Fuse Keeps Blowing On 04 Plate T3s
ap1050
can anyone help my 2004 avensis t3s keeps blowing side light fuse. Have removed bulbs front and back when fuse blows but when new fuse fitted blows straightaway. if fuse replaced next day after car stood over night it dose not blow ????.
hello
i deem you''ve a short cut there.
have el. circuit tested
cheers/Igor
If your Avensis has a headlight levelling switch try removing it and disconnecting the multiplug. I had a similar fault on a Yaris 3 years ago and it was the switch at fault. If not, and you've got a towbar, check the wiring socket for water ingress and corrosion.
