Hi, my 1992 Lucida has jus failed the MOT on the rear Nearside and offside top suspension bushes.
These are proving a pain to locate the parts.
Can anyone advise me where to get these parts from?
Cheers.
PM me the chassis number AND model code, I will price them for you
Kingo :thumbsup:
Buying from Toyota is a good thing as you lnow the parts will fit.
You can however save yourself a bit of money however if you realise that many components including suspension parts are intechangeable between the Estima and the Previa.
If you go down to your local scrap yard and find a Previa that uses the same rear axle as yours I.e. solid or independant suspension take down its chassis number. Then use this to get prices on yhe part you want but from a Previa.
Compare these with the price quoted for the Estima part and sometimes you may find a big difference, not always thougjh.
Obviously this does not work for the engine as the UK Previa, thankfully, was never fitted with the diesel engine.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
