Toyota Corolla Gti (ae92)
Twincam.GTi
Toyota Corolla GTi (AE92) - Some useful part numbers
Don’t know if these Toyota part numbers might be of use to fellow GTI owners when using Mr T for the odd bit?
…and I fully realise some of the part numbers will probably supersede to a newer number (‘Parts King’ is the Guru on this!)
AIR FILTER (Early type)
17801 – 16020 – 83
SPARK PLUG
T90919 – 01131
SPARK PLUG LEAD SET
90919 – 21395
RADIATOR CAP
T16401 - 63010
‘TOP’ RADIATOR HOSE
16571 – 16090
‘BOTTOM’ RADIATOR HOSE
16572 – 16070
ACCELERATOR CABLE
78180 – 1A101
EXHAUST HANGER
(Rubber type – 3 used on system)
17565 - 15070
EXHAUST PIPE TO BACK BOX SEAL RING
T90917 - 06045
HEADLAMP COVERS (Clear)
T00051 - 30001
RUBBER mats
(General use / cut to shape etc..)
TGBNGA – 25007 – 01
INDICATOR LENS FRONT
T81521 – 12580 - Passenger side
T81511 – 12580 - Drivers side
GEAR LEVER KNOB (LEATHER)
T33505 – 12150 - CO
WHEEL STUD (Not nut or bolt but
actual fixing in hub)
T90942 – 02047
wiper BLADES*
T85212 – 12290
T85222 – 12700
*COULD BE SUPERSEDED BY
T85220 – YZZAS
T85220 – YZZAL
SMALL FIXING SCREW FOR
ABOVE (If you were to lose them!)
T90099 – 00925
wiper BLADE ‘WING’
T85225 – 12820
Battery (Optifit)
T28800 YZZAE
TOOL BAG (BUT IS NO LONGER GREY - IT'S NOW BLACK)
09120 - 10030
'FOR LIFE' COOLANT RED 'TOP UP BOTTLE
T08889 - 80006
