Gen 7 Pedals
springfield
my 04 [140] gen 7 comes with rubber pedals, when did the metal versions appear ? or were they optional accessories? cheers :rolleyes:
The aluminum pedals were available througout the production run ('99-'05) but I think they were only standard equipment on some models. (T-sport, etc...)
However you can buy just the aluminum pedals from Toyota and upgrade, I did that at the time, looks much better :)
Here are the part#'s if needed:
Footrest:
58192-20090 LHD vehicles
58191-20100 RHD vehicles
Clutch and brake pedal pad:
31321-53010
Accelerator pedal:
78120-20790 LHD vehicles
78120-20780 RHD vehicles
Genuine Alloy Pedals were only fitted to the face lift 140 with the "Style" Pack. They are available from Toyota at the bargain price of £85 :rolleyes:
The 190, T Sport and GT models have imitation Alloy Pedals as detailed by Hawke56.
Also, I think that the genuine alloy pedals don't come with an alloy footrest, they look like this I belive: (on LHD)
The 190/T Sport always had the full alloy-esque pedals and footrest.
The pedals in this photo are the aftermarket pedal covers available from Toyota for around £70 I think. You remove the rubber pads on the brake and clutch and bolt them on. On the accelerater, you actually screw the cover into the plastic pedal.
Yes, the part numbers in my first post are for the 190/T sport alloy-eqsue pedal set, the part# for this set in the picture is 08487-20810 for LHD, not sure about RHD it could be the same.
