Need Advice For Changing Headlight Bulbs
ClubMem
I have an Avensis hatchback 2003 D4D T3X diesel. I need to change the front headlight bulbs. Is this an easy task? Could anyone give any advice on the steps I need to take to do this. This is obviously my first time. Many thanks.
Try here >> Avensis Headlight Bulb
If changing main beam bulbs, straight forward enough to get hands in you can figure it for yourself. If dipped beam bulbs a bit more involved, N/S bulb quite straight forward just remove black plastic cover to access bulb a little fiddly but take your time & you should have no problems. O/S is the tricky one very little room ( do not remove bumper as some people suggest) just loosen H/lamp & O/S corner of bumper. Just at top rear point of bumper behind wheel trim you will find 10mm bolt remove this & you will have access to black locating strip attached to bumper this needs to be loosened, this should create enough room to move H/lamp around without removing it to allow bulb renewal.
