Engine Man. Light
kevnasha
hi everyone..any thoughts on the best way to remove the engine management light permanently as it is on all the time. doi need a radio code on the 03 t3 avensis with sat-nav if i disconnect the Battery?? cheers guys
hi everyone..any thoughts on the best way to remove the engine management light permanently as it is on all the time. doi need a radio code on the 03 t3 avensis with sat-nav if i disconnect the battery?? cheers guys
Hi Mate,
If you have an avensis in new shape than you can remove a EFI fuse for about 2 minutes and it should go away.However bear in mind that if this will come back within a short period of time you should consider go to a service to check.You may also buy a code reader on eBay such as
http://cgi.ebay.co.uk/OBD2-ELM-327-USB-Sca...id=p3286.c0.m14
I have just bought it,but it will take a several days to receive.Soon I will get it I will keep you update.
Best
Wojciech
