Telegraph Review
iggy
Just read a review by Richard Dredge for the telegraph on the gen 7 celica. He claims that it is not unusual to top up by a litre of oil every 600 miles once the celica has done more than 40,000 miles!
In your experience is this the case? If so it would really put me off buying one. :eek:
Don't worry iggy, he's referring to the pre face lift 140 (circa 2001). As you're looking for a 2006 model, the problem was fixed from "52" Reg. onwards. The only weak points on a face lift are corrosion on the alloys and Brake Discs.
Don't worry iggy, he's referring to the pre face lift 140 (circa 2001). As you're looking for a 2006 model, the problem was fixed from "52" Reg. onwards. The only weak points on a face lift are corrosion on the Alloys and Brake Discs.
Whew! Thanks Scarlett.. :thumbsup:
