Engine Oil
ADRIVER
Hi all, Can anyone tell me, will putting Diesel engine oil into a petrol engine do any damage to the petrol engine?
Thanks :huh:
Thanks :huh:
Yes, i i wouldn't do that. It could totally ruin the engine.
Diesel has a much lower selfinflame temperature, than petrol. That's why diesel engines don't need any sparkplugs to run.
Putting petrol in a diesel engine wouldn't do any more damage than that the engine wouldn't start. Putting diesel that selfinflames when compressed, in a petrol engine, that's designed to ingnide the petrol with sparkplugs is something i wouldn't want to try unless the engine was on it's way to the junkyard
Thanks :huh:
hello
never use diesel enging oil in petrol one.
the first oil is designed having all additives for use in diesels (especially alkalinity number )---> this alkalinity reacts with sulphur acid formulated from sulphur in diesel and moisture in the air/diesel --- > this alkalinity gets acid neitralized to prevent acid attack to the internal parts such us liners; rings etc.
cheers
Igor
Thanks :huh:
hello
cheers
Igor
thanks for your reply but I want to be clear about this. I'm talking about the oil used in an oil change. A mechanic told me that there is no difference between the oil used in a Diesel engine and a petrol engine at oil change. He told me that the diesel engine oil was better than the petrol engine oil. Is there a way I can tell from the oil in the engine what oil was used?
Thanks :huh:
hello
cheers
Igor
hello again
in case those mechanic will be responsible for the engine problem - then go ahead -- but be sure this is huge violation of the maintenance rules.
i know MrT offers lube oil for both petrol/diesel as the same oil -- but it is better to use it in case of MrT responsibility.
cheers
