Bonet Problem....
epaulina
My husband tried to lift the car bonet today and one of the teeth that catches into the latch has broken off. There were two and now there is just the one left. We're not having the car serviced until next month. Is this likey to cause any problems, I can't see how we can get a replacement for this as its just a small part. We're not experienced with cars and my husband is really worried that the bonet will open on its own while driving.
Any help and suggestions will be greatly appreciated.
Paulina
Hi
Not too sure which bit you mean.... all I would say is that if the bonnet does fly up at speed it is terrifying and you will probably crash or at least hit the curb and damage something, let alone one smashed windscreen and a new bonnet and hinges.... it is not worth taking the risk. Bring the service forward or take it to Toyota or another garage a.s.a.p.
If you have to drive it then tie the bonnet down somehow to physically stop it coming open....
Pete
Hi
Pete
Thanks Pete
Not sure how I can explain it. There used to be two teeth (under the bonet ) that went into the latch when closed, now there is only one. We have a Toyota garage near us, do you think they would just have a look and tell us if/how it needs replacing?
Hi
Pete
Thanks Pete
Toyota always seem pretty friendly to me. They will certainly know how to fix it and what parts you need, if they are expensive then try a breakers, tell them you can't afford it this month and will see them later.... There are loads being broken on eBay
Pete
