Rear Brake Disc Removal
GVS
Looking for some help here.
Just bought come brake pads and discs for my 03 Avensis 1.8. Thinking it would straight forward - done loads of other car types in past, but to my displeasure I could not get the discs off. Looks like handbrake uses brake shoes inside the disc while main brakes are pads on outside.
Their is a peek hole which I am sure is for this very reason, but I could not see what to do inside said hole. I am sure a special tool should be inserted, twisted - or something and the shoes contract to allow the disc to come off.
Any help appreciated.
Gary
Gary
HI GARY,
YEP, INSIDE THE HUB OF THE DISC THERE ARE A PAIR OF SHOES, REMOVE THE GROMMET FROM THE INSPECTION HOLE THAT YOU HAVE FOUND, THEN USING A FLAT SCREWDRIVER, INSERT IT HROUGH THE HOLE AND THERE IS A SMALL COG WHICH DEPENDING ON WHAT SIDE OF THE CAR YOU ARE ON YOU WIND UP OR DOWN A FEW CLICKS, THIS CONTRACTS THE SHOES AND THE DISC WILL COME AWAY.
DARREN
Gary
HI GARY,
DARREN
Thanks Darren,
I saw the grommet and inspection hole, but could not locate the cog. Where do you locate the disc to see the cog? Is it Top dead centre, bottom or on one of the sides? I spend a little time with flash light trying to see something that might do this, but could not locate it. The handbrake cable is located at the bottom of the hub, so assuming it either at the bottom or the top.
Thanks for your help again.
Gary
Gary
HI GARY,
DARREN
Thanks Darren,
Gary
Its at the bottom from memory, you should make it out with a light. when you insert the driver it kinda levers against the inspection hole and turns the cog, unless seized, but lets not go there !!
Darren
Gary
http://toyotaownersclub.com/forums/index.php?showtopic=84814
Gary
Thanks all who helped. Dead easy when you know how.....
Thanks Again.
Gary
