Belt Or Chain On Starlet
SF695
My mother has a Toyota Starlet 1.3 from 1999, with the 4E-FE engine. Can anyone tell me if this engine has cambelt or chain?
It's a belt on the Starlets
Thanks. Time for replacing then
It's an easy job to do on these cars.
Always worth changing if you're in any doubts.
Guess everything is easy if you know how to do it :)
But i've never even opened a belt cover, so not sure i would want to go as far as changing the belt
My own Avensis is, as i write this at the mechanics, having it's cambelt changed
Belt should take a couple of hrs in the shed, or over an hour in the workshop. But as you say, if you have not changed one before best leave it to your mechanic. But it is one of the easier belts to change.
