1999 Corolla 1.6 Sr
adecbr600
Hi There
Sorry- Correction - it is a 1998 model!!!
I am about to change my discs & pads on my corolla,can anybody confirm the correct torque settings for the caliper guide bolts & caliper mounting bolts.
Many thanks
Ade
Front brake caliper -
Caliper Guide bolts (which hold 'removable part for brake pad only change' caliper assy to torque plate - which in turn is mounted to hub carrier)
25 Nm (18 Ibf ft)
Caliper Mounting bolts (hold assembly that is mounted to hub carrier)
88Nm (65 Ibf ft)
:o
And!
When apart give the 'slides'/slide bushings (what the guide bolts go through, rubber boot at each end) a damn good clean and coat with copper grease for they are known to stick and thus you will have a dragging caliper.
Hi
Many thanks for your help-will give that a go.
Cheers
Ade
And!
