Performance Drop Vvtli 190
110jto
i have owned my gen 7 190 for a few months
all been well
last week or so the performance has dropped off
new plugs(iridiums) ,oil,flter,air filter etc fitted
no warning lamps on
still kicks in at 6200 rpm but the low speed torque has just suddenly gone flaccid
any help would be appreciated
thanks
110jto
Mine does this when run on cheap supermarket fuel, she doesnt do it when running on Optimax.
i shall try some super unleaded then ;)
ive gotta admit it,last nite on motorway when it was 5 degrees centigrade it really flew
i thought it mite be a sensor?
or does the warning lamp come on if a sensor is down
oh,mileage is 113,with fsh
whats the terminal mileage for these or when do they start playing up
mines great but sounds a little "piston slappy",maybe they all do that
i dunno
thanks for your help,,
any more things i should try celica people?
If you are worried about it take it into a Toyota Centre for a once over. They know the cars better than most.
Don't believe that Super Fuel will make a blind bit of difference - it may but just as well... may NOT! One tank won't change it anyway. Supermarket fuel is supplied by the giants like BP, so nothing cheap about it really is there.
Toyotas run forever so mileage won't make the difference so long as it has been serviced and looked after and renewable parts replaced as and when.
Clean your MAF sensor. Cold weather improvement points to that being a possibility.
thanks for advice
whats best way to clean it?
thanks once more
thanks for advice
thanks once more
Have a search in the different forums, there are different opinions. Becareful though as they are very sensitive and easy to break.
Re the fuel, my car has a different sound on tickover when its on Shell Optimax rather than Morrisions normal 95 Ron Unleaded, it just ticks over smoother and pulls stronger through the rev range. I dont think this pychological, non of the other "super" fuels give the improvement.
thanks for advice
thanks once more
cleaned maf senser carefully
seems the same
doing approx 17mpg
gonna have to have a diagnostic aint i :o
