Battery Clamp Missing
amc1902
Does anyone know where I would be able to pick up Battery clamp for an 04 Avensis? also, are they easy enough to fit?
Just thought I'd try on here before paying Mr. T.
amc1902
not something I've had to buy before, but this should be something you can get from a motor factor or auto electrical place.
I bet Halfords sell gold plated ones for the boy racers
Does anyone know where I would be able to pick up battery clamp for an 04 Avensis? also, are they easy enough to fit?
amc1902
Contact car breakers in your area for a Battery clamp. The clamp is secured by a small bolt into at the front and a hook locates in a hole in the Battery shelf and is secured by a nut onto the clamp. Very easy to fit, you just need a 10mm spanner.
Contact car breakers in your area for a battery clamp. The clamp is secured by a small bolt into at the front and a hook locates in a hole in the battery shelf and is secured by a nut onto the clamp. Very easy to fit, you just need a 10mm spanner.
Good point - are we talking about a terminal clamp (which I assumed), or the bracket to hold the Battery in place?
