Hi i have a toyota previa 2.4 petrol. The front pads are about to wear off and need replaceing and just needed some advice which ones to get. In my local auto parts shop the pads are made by mintex and is only £31 and in toyota its their own gunuine make and its about £47. Which would be better are mintex a good make or should I just stick to toyota's own make. Thanks.
Just use Mintex or buy these
http://cgi.ebay.co.uk/TOYOTA-ESTIMA-LUCIDA...id=p3286.c0.m14
ignore the name Estima, it is just the name given to the Previa in the far east. All you need to check is whether or not your car has ABS and the diameter of the discs. The same seller sells pads for non-ABS models
