Nokia Free Kit On Yaris
kompressor
Hello! I'm from Portugal and here no one can help me. I have a Yaris from 2002 and I want to put a Nokia Ck-7W (?) hands free kit. The problem is the connection to original radio in the car. Can anyone explain to me? Do I have to buy anything? Another cable, connector? Thank's!
The CK7W comes with a standard interface to the ISO wiring plug. If your yaris has one on these (you will have to check) then you will be fine, if not you will need an adapter, the place you get the CK7W from should know if you need one or not...
Pete
You need an autoleads adapter. I don't know where you can get one from in Portugal. But in the UK you can get them from a number of places.
This is the one you need: http://www.siocommunications.co.uk/06-062B.html
You will also need to make sure that it comes with a 4 pin rather than 6 pin power adapter, The one in the picture has a 4 pin adapter, it is black at the bottom of the image. You will find that this automatically mutes the radio, and it will just plug into the back of the radio, the existing radio leads will plug into this new loom.
I have put quite a few kits into Yaris now, so if you have any more questions or problems give me a shout.....
You might find a dashmount handy... www.dashmount.co.uk
Hope this helps.
