Rav4 T180 Wheel Dimensions
hughgengine
I'm looking to add a spare wheel to my collection of 4 on my Rav and I was wondering if anyone knows the what the standard 18" wheel dimensions and specs are? Is it a 7.5J? What's the offset? And is there any other info I'd need?
You need wheels with a PCD (basically the diameter of a circle that passes through the 5 studs) of 114.3mm, an offset of between 35 and 45mm and a bore of 60.1mm (courtesy Robert)
18 inch 7.5J
If you tell the supplier the tyre size which is 235/55R18 you should have everything.
That's great thanks Anchorman (and Robert). I don't know where this forum would be without you!
Cheers.
