Specs For Satnav Head Units?
St Thicket
Thanks shcm!
For the DVD-input; it seems like I need to make a AVC-LAN driver to be able to use the input... seems like a lot of work! I know there's a polish guy that has made his own MP3 player this way. It would have been really cool to make it work, but then again the time is an issue...
By the way, an interesting publication about the AVC-LAN: http://perens.com/works/hobbies/ham/prius/...lan/avc-lan.pdf
If you have an old PC, use two 2-pin connectors (HDD light, ON Button etc..).
These connectors fits horizontal on pin 1-2 or 3-4 of the unit.
@shcm, Number 90980-12211 does not exist in the EPC system.
But ordered a 4pin Female ´video connector´ for a ´07 Toyota Sienna.
Big chance it is the right one, otherwise...lost 5 euro.
Next week i know (have to come from Japan i guess) if it fits and a partnumber.
I've been there before. A lot of the harness end connectors aren't, with the EPCs we have access to. That doesn't mean it doesn't exist. True, it may not exist, but I suspect it does:-
http://translate.google.co.uk/translate?hl...12211%26hl%3Den
Nice links!
If it is a part of a Toyota, it can be ordered. You only need numbers (partnumber, licenseplate number, vin number, etc..) for a quick find.
Sometimes numbers change and the EPC system at my local dealer can track the number to get the newest one.
Almost the same with the connector, only have to select a vehicle first. Then the number was recognized.
And...sometimes i tell my toyota partmanager how to use EPC. Always look behind the ´next´ button... :)
