Air Flow Sensor
kangzy
guys how much will it cost from toyota if i was to ge a new air flow sensor fitted including the wiring??
cos the wires were streteched and snapped a while back due to the induction kit .. managed to extended the wirers slightly but i just want everything back to normaland knew rather than having duck tape here and there
cheers
shaun
Are you sure its the sensor and not the plug thats damaged? The wires don't go into the sensor they go in to the plug. The below will sort you out if it is only the plug:
K & N Typhoon Induction Kit - If it breaks your MAF Plug by snapping the little black wire.
These parts are the plug, its internals and additional wire: T-90980-11317 & T82998-12440.
£26 from Mr T - Not Cheap but it does the job properly. Any Autoelectrician will fit and repair in less than half an hour.
As you can see the plug has changed along with the wires
yea sorry its just the plug.. cheers mate!
ill give it a go.. btw ur cai looks good
shaun
shaun
Cheers Shaun
This fix will sort you out, its not the cheapest but after the grief this caused me (limp mode etc) i am happy to pay a bit so it wont happen again. Mr T will be very confused when you ask for these parts, they had no idea what they were when i ordered mine! :rolleyes::lol:
