Corolla Verso Speedometer
itchy
Hello,
i have Toyota Corolla Verso '04 and I have a problem with its speedometer. It doesn't dim when i turn the lights on. It stays so bright like when the lights are turned off. What should i do and where should i look for the problem?
Can you change the brightness at all? There should be two adjustments one for lights on and one for lights on shown by a different number of === on the trip computer display when you cycle through them.
