hi there i was wondering if any1 knows how to fit a headunit in an aygo? :o i dont know how to remove the stock one do you have to remove the panell 1st ? please get back to me asap email me the answer gunner_69@hotmail.co.uk or just right on here althouh iam not to sure how all this works as i am new :)
Since you're new, did you even bother doing a SEARCH???
It's in the upper righthand corner of your screen and searching for headunit gives many an answer...
You need to remove the console around the radio, which is done by pulling of the fan knob and unscrewing
the then exposed screw,then pry the top panel from the rest, working from the knob upward.
Once you have 2 to 3" of room undo the 2 or 3 plugs on the hazzard- rear defog and A/C switches.
Now you can see 2x2 metal prings keeping the radio in the plastic surround, push those in and the radio will slide out.
When fitting a new radio you have to remember that the power wires (yellow and red) need
to be swapped,else you'll loose your presets and such every tim eyou turn off the ignition.
