Washer Jets
D1 gUNN
Part nr. Part name
85381-12340 nozzle sub assy washer -2°
85381-12330 nozzle sub assy washer 0°
85381-12350 nozzle sub assy washer +2°
85308-12010 nozzle sub assy washer +3°
85308-12010 comes in a bag with all three nozzles.
So you need this part number X 2
The angel is marked on the nozzle
Old part number New part number Part name
85211-12510 (*) 85211-12511 RH LHD Front wiper arm (TMC Auris)
85221-12450 (*) 85221-12451 LH LHD Front wiper arm (TMC Auris)
85211-02180 (*) 85211-02181 RH LHD Front wiper arm (EMC Auris)
85221-02190 (*) 85221-02191 LH LHD Front wiper arm (EMC Auris)
Wiper Blades are changed in production frome:
Modellkode Fabrikk Fra chassisnr. Fra dato
ZZE150 SB1KM56E10F016707
ZRE151 SB1KV56EX0F048827
NDE150 SB1KC58E00F024393
ADE150 SB1KD56E40F020444
ADE157 TMUK SB1KB56E50F004906 11 des. 2007
ZZE150 NMTKM56E20R011977
ZRE151 NMTKV56E30R020006
NDE150 NMTKC56E90R014331
ADE150 NMTKD56E10R008570
ADE157 TMMT NMTJB56E50R002997 23 nov. 2007
ZZE150 JTNKM56E101005422
ZRE151 JTNKV56E601015179 7 januar 2008
NDE150
ADE150
ADE157 TMC (Kanto) Ikke lenger i produksjon.
Thanks for the info, the part number can be ordered, but TGB dont have stocks until end of March, however, that part number is not listed anywhere on my systems, so maybe we might get some further information on our next update discs
Kingo :thumbsup:
So which nozzles Auris' have from the factory? And will I need those +3 jets
to make the low profile wiper arms helpful? (Will I get any help by only changing
the wiper arms and not the jets? Have allready upgraded them once).
Best regards, Alex
Kingo :thumbsup:
We have 7 of theese in stock here in norway, and delivery on the rest 24 march 2009
Not sure what the auris has original, but the lower wiper arms will help even without +3 degree jets.
Thanks for your help Fred! :) Going to call my dealer this week!
Some pics would be nice indeed...
Best regards, Alex
Hello again! Wanted to ask a couple more things:
Are these "original" compared to low-profile wiper arm part numbers? What does TMC and EMC Auris mean?
NDE150
ADE150
Why are the Wiper Blades being changed to these models?
Best regards, Alex
Tmc= produced in Japan
Emc= produced in Europe?
Do not understand what you mean about are these original compared to....... tbc
The first number is the part who is on the car frome the factory, and the second number is the part number for the lower arm.
The change in production I guess is because they found out they where to high, and changed them on the factory line.
So all cars frome that chassinumber have the modified arms.
So mine is 1ZRE151L NMTKV56E50R039...., compared to ZRE151 NMTKV56E30R020006 , does this mean I already have the lower arms installed from the factory?
Regards,
Svet
Maybe you did not understand me, but still you explained everything so that it's clear to me now. Thank you for your big help, again :)
Best regards, Alex
Regards,
Svet
No, you'd allready have them if you had ZRE151 NMTKV56E30R020006 , but your number is not on the list, that means you don't have the lower ones. The lower arms are changed to the ones on the list!
Correct me if I'm wrong guys :huh:
Best regards, Alex
I think you DO have them!
The chassinumber means that every car AFTER the number I posted have the lower arms. (I think......)
Took a picture today......
Hmmmm, might be able to get a better picture when this ******* snow is gone....
  • 8 months later...
Thanks for the above information. I bought a T Spirit last month and, like everyone else, discovered the washers did no more than spray the undersides of the wiper arms when travelling at any speed. When I failed to find an adjustable jet, I looked on here and found this thread.
My dealer took the car in this morning and immediately said they would replace the jets under warranty. They only had +3 in stock but I'm happy as that strikes about halfway up the screen with a wide spread pattern. (Now all I need to is remember to top up the windscreen washer tank regularly as it certainly throws plenty of water onto the screen. ;) )
Again, thanks to everyone for all this helpful information.
