02 Sensor
HitenV
My engine management light came up a few days ago - took it into a dealer. Error code on the diagnostic test came up as P0141. The 02 sensor is faulty and needs replacing.
The information on the diagnostic report reads " 02 Sensor, heater circuit failed, Bank 1, Sensor 2 "
I'd be grateful if someone can tell me
where I can get a replacement sensor from (Toyota - £154)
how I can find / replace this sensor.
Car details - Avensis 2001 CDX 2.0 Petrol 5 Door Hatchback. Engine Code 1AZFSE.
Much appreciated,
H.
If ypu don't mind waiting a little while, then get your sensor from here?... as for fitting it's a case of useing an o2 sensor socket and unscrewing it, then unplug the other side and fit the new one.
Hi Mate,
I have found in my car fault code P0136 "O2 sensor circuit" which is O2 sensor Bank 1 Sensor 2 correct me if I'm wrong.
MY car is Avensis 2003(new shape) VVTi,T4,semi-auto.I went to the recommended website but there is no Avensis to choose?What other car has got the same O2 sensors?
Is it dificult to change it?
Regards
Wojciech
  • 4 weeks later...
Guys;
My Engine Malfuction indicator came on and I checked out the code which turned out to be P0155 - Bank 2 Sensor 1. Please can any of you recommend where I can buy this part and how to fit it.
Toyota Avensis 1.8 (2002) model.
Any info is much appricated
Michal
