Avensis T22 Roof Antenna Replacement
marbet
Hi fellow members.
I have a (small) problem and i hope one of you has the answer.
On a saturdaynight some *#%hole broke of the entire antenna on the roof of my T22 station.
The antenna broke so far down that i can't get it unscrewed anymore.
therefore i need to replace the entire unit.
are there special tricks to do that?
For instance, how do i take the light unit near the front window on the roof out.
I mean the unit which also contains the sunglassholder.
I can't find any screws!
I hope i get an answer from one of the readers.
Thanks already.
Excuses if my english is not superb. I did my best :(
  • 2 years later...
As far as i can remember, the mounting screws are located behind the map light lenses.
To get the lenses off, you just pry them out with a screwdriver or a flat knife.
