04 Corolla Tsport
TSPORT@TTE
Hi everyone hope you can help! Had an 04 plate corolla TSPORT for just over a year fantastic car but it has developed a single knock when setting off from a junction, i did'nt know if it could be a little movement from the brake pads or discs after use approching the junction.
Any ideas would be greatfully recieved.
you know what mine does that in the morning when i first start it up and pull off, just a single knock! its fine all day then.
havent got a clue what it is, maybe its just a common snitch on them :(
Are you applying the handbrake at a junction? Could be the handbrake shoes locking up...?
Any idea where the knock is coming from?
That noise is the sound of the ABS calibrating itself and is quite normal :thumbsup:
Hi no i'm not applying the handbrake,it sounds like its coming from the front but i'm not sure where. It only happens once everytime i set off from a standing start i don't get anything when changing gear.
thats sounds about right, hopefully anyway ;)
