Fitting Mudflaps To T180
bomber06
Just received a set of mudflaps from Kingo for the RAV. Can anyone give me any hints and tips regards fitting.
Any help would be greatfully received.
Hi bomber06
I found them easy to fit, it's pretty obvious where they go and they are straightforward to fit. You'll need to turn the wheels to full lock in order to get a decent sized screwdriver in, but apart from that, no special problems
Good luck
I plan to buy them for my T180.
For completeness.
I checked installation manuals -> http://techdoc.toyota-europe.com/Aim.aspx?menuitem=2
The mud flaps come in two designs versions : for cars with or without overfenders ...
The installation procedure seems to be a bit different depending which of the two types you plan to fit (for T180 the correct model is "with overfenders" ?) ...
Pls, note that it seems a drill might be required.
Also a wheel must be removed (unless you can drill the required holes without removing it) ???
So double check the details before you kick off with the installation ...
