Drive Axle Question
jimmysghia
hello all, i'm removing an engine from 91 corolla wagon with 5spd trans. removing both as one unit. was hoping that some one could tell me if the drive axles pop out with a bit of pry bar persuasion from the trans?
try a chisel and hammer, a pry bar might damage the gearbox casing if not used carefully. Yes they do pop out, they have a retaining clip on the shaft so they will only slide out a little before you must force them out.
