Oil Catch Can
GT-FOURNZ
hi all im in the process of geting a catch can but cant seem to find any with 2 inlets and to outlets does it matter if i dont hook it bak up to the air intake or will it cause problems
it needs somewhere to vent to, either air or back into the inlet. so if you add a catch can it need a minimum of to connections, one to the rocker cover vent and one that vents to air or air inlet.
