Guys,
I am looking for parts for the 18r-g in my TA23GT. i am desperately in need of carb overhaul kits most importantly but also engine rebuild kits ( i have 2 but they are both 18r which is different).
If anyone has a pair of Weber DCOE45's they do not want i might be interested in them instead of rebuilding the Mikuni's that are on there now.
Any leads would be greatfully received.
Thanks in advance
Mike
Hi
I bought carb repair kits for mine from www.carburetters.co.uk
They cost me about £75 and you didn't get a lot for your money, but if you're going to pull the carbs apart you might as well have the gaskets to rebuild them.
That's about all you get along with a fuel pump diaphragm for each carb.
Good Luck
Have a look on eBay, there are usually quite a few!
