Vvtl-i Vs V-tec
theenemywithin
I was watching an old episode of Topgear last night.
Mr Clarkson made a comment that over 15,000,000 V-tec engines have been manufactured and not one has failed.
This is obvioulsy very impressive statistics for Honda power plant.
So i was wondering if any such stats have been annouced for our VVTL-i engine.
Anybody know anything???
yes its a half truth. i know people who have blown, for example, an Accord Type R engine (2.2 Vtec)
what they mean is that the VTEC unit hasnt broken/caused catastrophic failure...but that doesnt mean that the engine cant blow a head gasket, or
spin a bearing like everyone elses....
The VVTL-i system was only found in the 2ZZ-GE engine. Difficult to get good statistics to compare with hondas V-Tec, which is installed in most of the Honda lineup. If you want to compare, get statistics for the vvt-i system, without the L
probably wont be as good as the v-tech the vvti reason being is most of the avensis etc that used the standard vvti had alot of problems in the past.
from my knowledge that is.
take it you mean i-vtec, vs vvtl-i
but the i-vtec has never had a technical failure because they have always blamed it on owner/driver error rather than on a mechanical failure on the engine.
i have heard quite a few cases on the vvtl-i engine of the oil pump making a rather nice hole in the side of the block, but again this is due to driver/owner error, so due to neither manufacturer not releasing truthful information, it is hard to discover the true figure of manufacturer error, ultimately leading to engine failure
All V-TEC engines have lobes that extend off the cam, this is why the 15m figure is quoted. So even a 1.4 Jazz has V-TEC in the same way as a Integra DC5 ot CTR, the VVTLI is a very rare engine by comparison. The VTE-C system is quite simple really, this could account for the lack of failures, comparing V-TEC to VVTL-I isnt really possible due to the numbers involved.
All V-TEC engines [...] The VTE-C system [...]
:lol:
Spelled VTEC mofos. That it's a more common unit means information is easier, but it also means it could fail more often than the rare VVTL-i.
How is it actually driving a T-Sport? I read some about it when it was launched, narrow powerband and that it needed chasing..
:lol:
Never driven a T Sport, but imagine you'd have to stay above 5000 rpm, to benifit from the horsepower and i for one, prefer to have a wide powerband
depends what you want, if you want a high reving FUN car that just goes crazy when you floor it, or if you want a steady and slightly progressing powerband. different ppl have different opinions and i want a sport hatch to be as fun as possible , and they aint anything as fun as when that lift kicks in through first and second etc or even better the i-vtec
ppl say you have to work hard for the power, but it doesnt take long at all to hit lift , what a couple of seconds if your in 3rd or 4th sat at low revs? and maybe 1 second ish if you in 1st or 2nd sat at low revs (these ppl dont know what hard work is)
:lol:
Honda claim is no failures from 15m units, the VVTL-I powerband is narrow but it easily keeps up with normal traffic then blows them away at the top of the rev range.
