Help Help Help Help
tamas
hi how are you all
my 1993 celica gt is overheating it ran it for an hour today in my drive was looking good all fans were working
we took out to the road it ran fine till we accelerated a bit heavier to go up the hill and the temp started going up
changed thermostat yesterday flushed radiator
i left the radiator cap of wen i started it up in drive today water didnt boil oveer until i reved it
anybody any ideas
think the heads gasket is away
check water and oil level
check air filter and piping for any blockage
if your head gasket has gone you will see thick white smoke from the exhaust
hi it is fitted with a k&n type air filter
i noticed the top pipe on radiator is very hot
the pipe which leads to the thermostat is cold
any more suggestions thanks
water and oil level seem fine
Not always!
Is your coolant system presurising ok? Is the Rad cap good? are you losing any fluid?
Not always!
cheers again
how can you tell if its presurising
I dont know, maybe run the engine for a bit the remove the radiator cap, lol, make sure you stand back
IMPORTANT...............Never remove the radiator cap with a hot engine................SEVERE RISK OF BURNING
