Water Sloshing Around The Front
tubaman
I park my 2002 Avencis 1.8 VVti SR generally under trees while at work.
I suspect that some leaves must have blocked the drains to my front scuttle ? near the front windscreen wipers as when I go around corners I hear a load of water sloshing around (especially when I take tight corners).
I`ve taken out the leaves that I can easily see but how to I remove the rest of the debris as it must have blocked the drain holes ? I just cant see how you get the the drain pipes/holes.
Any ideas ?
Any ideas ?
I presume you will need to remove both wiper arms and the black plastic scuttle. Clear out any debris under there and you should be able to find the drains. They should be in the lowest point at the outside ends. (provided that Toyota build them like everyone else)
Haven't actually had the problem with mine but the info should be good. I am sure someone else will soon shout up if it isn't.
