Electrics & Fuse
dickyp
<newbie posting> please bear with me :rolleyes:
I have bought a new Dome Fuse for my Toyota Avensis Verso Estate. Its a really big brown one, I think 60A
The spare part bag calls it the "fusible link"
The guy in the Toyota garage said that the fuse is secured underside with a locking pin - so this must be taken out before the fuse can be changed
I have unscrewed two bolts to literally take the fuse box off - but that has not got me any further forward
Any advice would be much appreciated :P
DickyP
a dome fuse wont be 60A. they are usually 30A at the most and the usual 'pull out' type.
if you look at the fuse you need changing there maybe 2 very small bolts you need to remove from the side of it. with these out the fuse should just pull out.
Mart.
