can anyone tell me where the jack is usually found in this as i cannot find it or the bar for lowering the spare wheel cage. cheers davy
MESSAGE PASSSED FROM CARLO T:
Report:
Hi, If it’s the same as my LUCIDA? First row of sets Behind on the driver’s side on the floor is a piece of gray plastic floor cover. You need to lift carefully as it is held in place by clips. Inside You should find jack and bar.
Thanks Carlo T :thumbsup:
