Another Question - Sorry! Tunit Power Box
Purdey
Hi All
Have a tunit power box on the Rav but it has been causing a flat spot in the rev range, between 2000 and 3000 RPM.
Removed it to see if it was the box causing this and it was. Can i get this box reprogrammed anywhere or is this a known problem with these?? Want to repair the box and put it back on if at all possible.
Thanks a Million everyone...
P
Purdey
I don't know much about these, but if the website is to be believed, and you have the "VC-R" fitted (it's the recommended one for the Rav4) "It features a harness with original plugs for ease of fitting and adjustable tuning, either manually with a 9 position rotary switch or electronically via lap top tuning. This Tunit has several variants and is easily adaptable to many other common rail vehicles"
Worth a look at the website
