Hazard Warning Lights Switch
faolteam
hi folks i have a Toyota Avensis Aura and my problem is that my Hazard warning lights work and the flash inside control panel, but they wont flash on the original switch itself wear the Red Triangle is, i did take that panel off and notcied there was a connection in grey and a connection in black one for the back window heater and the other for the hazard warning lights, but there was also another white connection which was out but i honestly cant seew ere its goes
Does anyone know if this might be the problem or is it suppose to be out or do u know anyway i can rectify the light not comoing on at the Red Triangle Switch. :rolleyes:
Good question. Have had my car 5 years now & have never noticed if switch is back lit or should flash when on. I allways presumed 2 lights flashed on facia when switch pressed. Wait for other postings, but i suspect the above is correct???
I know it definitely lights up, just not sure if its a fuse ???
I never knew that. I suspect possible blown bulb in switch in that case ???????? As i would have thought switch to be wired into main Hazard circuit so if fuse blew it would knock out complete hazard light circuit ?????? Sorry you don't give year of car.
Just checked, system has shared fuse for Hazard/Indicators in number 1 fuse box placed just above drivers footwell. Pull down trim to access.
2000 year,
but i did open it and theres a bulb in it in a grey case with a x sign on it i think u have to ge the whole casing
