Has anyone had a problem with electric windows jamming, this morning when closing the drivers window the back of the window moved up and the front down a little when half closed, this jammed the window until I fully opened it and closed it again.
What with the water leak repair last week (which might still be leaking) and now this I'm really starting to doubt the build quality of this little car :(
No - never jammed. Let's hope you have no more jams and no more leaks.
From what I've read on the internet this is not just a problem for electric
windows; the hand-crank version can experience the same problem.
I suppose this has something to do with the design of the window tracks.
Mine did the same, the clamp for the glass at the rear of the track (inside the door) is perhaps a little loose, just push the window down and it shouldn't do it again, ...sorted mine ok (and my leaks are cured too!)
