Boost And Fuel Cut
twodrunk
:wacko: hey i was jus wondering if anyone can help me out with boosting my standard gt4 st205. i would like to boost it to 14psi and how to diconnect the fuel cut and rev limit on my st205. any infomation would be appreciated thank you.
Your GT4 should boost to 14psi anyway, im sure mine goes that high.
You cant change the rev limit really without spending major $$$
Buy a Fuel Cut defender to take off the fuel cut and get a boost controller to raise the boost.
Do not exceed 1.2bar on standard pistons though (approx 17psi) because this will melt the pistons as dawsey will tell you :D
Hope this helps :hokus-pokus:
You should be at 13psi which is a little under 1 bar.
Fuel Cut on the ST205 occours at somewhere between 1.2 and 1.3 bar so you shouldn't need to mess with Fuel Cut Defenders IMO.
If you want to raise you boost higher I would look into getting a relief valve.
Leeky - 1.2 Bar should be fine on standard pistons - providing there is no detonation. Use something like Water Injection to give you a safety margin.
