How To Change Clock Time? - Avensis Tr D-4d
BonnyBute
Hi there, I've been trying to change to clock in my new Avensis for 2 weeks, it's aint happening, nothing in the book, twiddled everything that can be twiddled. Please help, I'm late everywhere I go aargghhh. :eek:
Any help will be greatfully appreciated. ;)
Bonny
Bonny
Mine is an 08 TR model, and on the right hand side of the middle of the steering wheel there is a button marked "Display" - press this and keep pressed in - the small LCD display on dashboard should then change to 3 options, one of which is "clock", select this by pressing the display button again and you should then be able to change the time.
Fabulous John, I will go give it a go...
Bonny
As instructions above but drivers door needs to be closed or you wont get the 'setup' menu to show on the display.
Mart.
  • 11 years later...
My 2008 Toyota Avensis needed oil maintenance. I got that done but can't get the clock to reset. Everytime i install the correct time then switch off the power the clock resets back to 12:00
Try disconnecting the Battery for 15 minutes.
