My Landcruiser Consuming Oil
nexsim
Lately my Landcruiser had been consuming oil. I've been doing oil changes too often.
Water level stays the same no overheating at all.
I notice that it seems to be loosing oil around the valve cover. Could that be the problem?
Do you think if I replace the valve cover gasket will fix the oil problem?
How difficult is to replace this valve cover gasket? I done it before but in smaller cars like honda civic.
Thanks in advance.
Thanks in advance.
If your landcruiser is using oil ,I doubt its coming from a leak in the valve cover,unless its pouring out.
It maybe a case of using the wrong grade of oil.
It can also depend on how many miles you have done
The valve cover is easy but it is vital that you get the bolts/nuts tightened to the same torque all over. Otherwise ,the cover will warp and allow more oil out.
This maybe the reason for the leakage you have now
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
