How Do You Remove The Auris Stereo?
colwall
I have an Auris T Spirit and I cant work out how to remove the stereo so that I can connect my bluetooth parrot that I took out of my previous car. I dont want to damage any of the fascias as I keep trying to work out what to do! PLEASE HELP!!
carefully remove the two silver side garnishes either side (they clip in) then lift off the upper air diffuser (above the radio) then there are 4 screws that hold the stereo in, 2 down each side.
hope that helps
in addition to that... its 4 10mm bolts... be careful when pulling it out.. it can often take the clip off the centre brace!
hope that helps
Thanks mate, I have tried to remove the silver sides but I cant get them to budge, Im too scared I will break them, what am I doing wrong?
if you take the plastic gear surround off first you can get your hands behind the pannel with the aircon etc and start unclipping from the bottom up.. then the silver sides r a gift
