Main Beam Problems?
coppen
Hi all,
need to pick someones brains.
i've got 2 Landruiser Amazons VX (1992 and a 1993) 4.2T and am having the same problems on both which i'm having difficulty solving.
Basically, the main beams aren't working on both.
The red relays in the fuse box have been replaced and can be heard working BUT when you flick from dip to main the mains do not work. All bulbs have been replaced but to no avail!
Is the black relay behind the red one possibly the cause??? Its stated as dip but has yet to be tried.
I've removed the black relays from both vehicles and a spare 1995 Cruiser and have found that the plastic around the connectors where the relay goes is slightly fused/melted.
Is this a common problem and again possibly a pause???
Any help gratefully recieved.
I would think that your problem is the stalk inside the car, have seen it mentioned before that the contacts burn, so take it off and give it a clean with electrical contact cleaner.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
