What Is Lift?
PHILGTS
I've heard different things about what physically happens when lift is engaged?
does the cam physically lift? if so what does that do?
I've also heard there's a heavier cam in there that becomes engaged at 6200 RPM which produces "lift"
I'm just curious as to how the 2ZZGE actually works
cheers,
phil
From Wikipedia:
VVTL-i
In 1998, Toyota started offering a new technology, VVTL-i, which can alter valve lift (and duration) as well as valve timing. In the case of the 16 valve 2ZZ-GE, the engine has 2 camshafts, one operating intake valves and one operating exhaust valves. Each camshaft has two lobes per cylinder, one low rpm lobe and one high rpm, high lift, long duration lobe. Each cylinder has two intake valves and two exhaust valves. Each set of two valves are controlled by one rocker arm, which is operated by the camshaft. Each rocker arm has a slipper follower mounted to the rocker arm with a spring, allowing the slipper follower to move up and down with the high lobe without affecting the rocker arm. When the engine is operating below 6000 rpm, the low lobe is operating the rocker arm and thus the valves. When the engine is operating above 6000 rpm, the ECU activates an oil pressure switch which pushes a sliding pin under the slipper follower on each rocker arm. This in effect, switches to the high lobe causing high lift and longer duration.
IIRC the engine produces 140BHP up to the point that Lift engages when an extra 50BHP kicks in :thumbsup:
From Wikipedia:
VVTL-i
what a comprehensive answer! thank you!! so is this "sliding pin" that you mentioned the infamous "lift bolt" that I've heard so much about?
