Problems Changing Up To Gear 3 And In Reverse
lovemerav
Hi I am hoping someone can shed some light on a little problem I have that has turned into a big problem.I own a Rav4 NRG 2.0 3DR which has done about 36 thousand miles. I have recently (past 3 mths or so ) noticed that it has been hard to go in to reverse gear. More recently and more worryingly, I have had problems getting the gear changed from gear 2 up to 3. I am finding that the Gear is not engaging all the time and I have to make very exaggerated movements to ensure it goes in gear 3 and not gear 5 (which has happend alot). The gear is fine in other Gears but the few times this problem has happend I have had to break suddenly and get the gear back in gear 3 and the Gear stick feels like it is not engaged in any Gear. I have not driven the car since it has happend recently ( 2 days ago) as I am waiting to take it in for a road test and don't feel safe driving like this.
I just wondered if anyone else has had a similar problem and what the solution and possible cost might be. I have had suggestions that selector rods and clutch may be the problem.I have no idea as I am not mechanically minded Any suggestions, ideas? many thanks
Hi and welcome to the club.
At the bottom of your gearstick are two cables that control the gear selection. Find a good local independant garage and ask them to have a look. the fact that you are having to make exagerated gear changes suggest there is something amiss with them. They could just be loose. I don't think there is anything nasty with the gearbox or clutch.
Keep us informed.
Regards
THE CLUTCH SHOULD BE GOOD FOR 60,000 MILes + (Aw see this Caps lock button - doing ma nut in!)
As anchorman says - its more likely to be the selection mechanism which just needs tightened
Ma faither s Punto has the same problem - runs in 1st and 2nd gear and seems difficult to get any other gear but its 100% the driver! :lol: :lol: :lol: then again he's 89!
Keep us informed.
Regards
Thank you both very much... I will let you guys know the verdict and most importantly cost (which i hope is not a lot)
Here goes for the feedback
Took the car to Toyota for a service and they suggested I change the clutch before having a look at the gearbox changing problem????? (which will involve me booking another appointment with them) They have quoted for them to fit new clutch ..............£1092.39
They found loads of other minor problems with their visual safety report (pollen filter blocked, Battery replacing- failed drop test, drive belt worn etc)but I am still none the wiser as to why my gear change is going a miss and do not want to fork out for a new clutch (and that might not be the problem). Gonna book an appointment with another garage and take it from there....
They found loads of other minor problems with their visual safety report (pollen filter blocked, battery replacing- failed drop test, drive belt worn etc)but I am still none the wiser as to why my gear change is going a miss and do not want to fork out for a new clutch (and that might not be the problem). Gonna book an appointment with another garage and take it from there....
oh my goodness (translated for a family website)
A RAV4 clutch will cost that at a dealer (top end price) but less than £500 at a Jap specialist. Total joke. I'd mine replaced with a competition clutch for less than £400
Find someone else!!
I doubt very much that a new clutch will affect vague selection of gears - it is to do with the gear linkage or at worst the gearbox. You can change the pollen filter yourself in minutes so take it to a decent local garage and let them look at the other items.
I know how to translate bothy's comment and I agree!
