Lights/controls Are They Suppose To Be Lit Up?
june123
Hi, i was just wondering if any Yaris (2007) owners know if the electric window switch for the driver is lit up at all times, as long as the key is turned to on? I would only expect it to be on when the headlights are on like other switches/controls.
Also, is the stereo mode button on the steering wheel suppose to light up, when the headlights are on?
Welcome to TOC :thumbsup:
The drivers side window switch lights up whenever the ignition is switched on..........and remains lit for approx 1 minute after the ignition is switched off unless you open the door.
The window switch is designed that way to allow the drivers window to operate for a while when the ignition is off
Not so sure about the steering wheel controls
