Owners Manual & Remote Fobs
saxon raider
;) Hi all,
As a new onwer of a W reg Avensis i have a few question to ask.
Can anyone tell me where i might get a owners maual for said Avensis? Also is it possible to but third party or after sales remote key fobs as one of the keys has a none working unlock botton, the lock button works fine. Hope someone can point me in the right direction.
Mnay thanks Sax :)
eBay probably is the best for both of them. Plenty of key fobs come up every so often on there, it might be worth trying to take the faulty one apart as sometimes the button slips from under the rubber on the early type key fob and just needs repositioning.
;) Hi all,
Mnay thanks Sax :)
Thanks alot will take a look see.
I've figured this out - and for anyone else who may have a similar problem with Toyota Avensis's or possibly toyota's with the Central locking on the key fob, here's how to programme the c/l on the keyfob to work and lock/unlock the car:
keys out of the barrel
open drivers door (leave open)
insert fault key and turn 'on' (dont start the engine)
wait 10 seconds
then press the 'unlock' button twice
you should hear the doors try to unlock/lock
and that should do the trick. worked for me first time.
Hope it helps,
  • 5 weeks later...
;) Hi all,
Mnay thanks Sax :)
Sax,
You can download the full manual repair avensis 2003 from this spanish web:
http://www.avensisclub.com/modules/newbb/v...739&forum=2
Control AT250307 http://www.megaupload.com/?d=WN8EW0LZ
Man AT250307_1/5 http://www.megaupload.com/?d=PE8UD48V
Man AT250307_2/5 http://www.megaupload.com/?d=FFAWLF86
Man AT250307_3/5 http://www.megaupload.com/es/?d=7X3PFYSW
Man AT250307_4/5 http://www.megaupload.com/es/?d=PM0CWE2T
Man AT250307_5/5 http://www.megaupload.com/es/?d=2IZWZ0F3
Cheers
it's strange - you can download all the accessory etc. manuals no problem but I can't find one for the complete car owner's manual :rolleyes:
closest is the quick guide http://www.toyota.co.uk/bv/OwnerServices/B...des/AVENSIS.pdf
